riven1950's avatar
riven1950
specific question on bug screens
I just bought bug screens made by Camco for my furnace outlet.
I plan to make screens for my HWH and frig out of aluminum screen wire. They will not be visible like the furnace so a perfect fit won't matter.
My question is : Will the aluminum screen wire be too small of opening so as to restrict air flow?
Opening is a little smaller than the Camco screen but I can't see where it will matter. Opinions?
2017 249rbs Apex if it matters.
Thanks in advance
  • I know, this sounds silly. But I put remnants of dog flea collars in the outside of the water heater and the fridge. Have never had a problem after I started to do this.
    Before, I had a water heater while up at Denali not start because of a spider web made overnight. They love the smell of LP.
    I do put a screen on the furnace output so mud dobbers do not get in there.
  • manufacturers probably recommend against the use of screens because some people not knowing any better will make flat screens to cover the openings.
    The stainless screens sold comercially for furnaces and water heaters are bowl or pan shaped and larger than the opening instead of fitting flat against the side of the trailer.
    That allows for the same amount of air that would normally pass through without restricting air flow. It is when the total area of all the holes in the screen is less than the opening that causes a restriction in flow. Making the screens 3 dimensional adds more total surface area than the appliance opening.
    When making your own screens the total surface area needs to be taken into account. Screen mesh has to be sized small enough to keep the spiders, wasps and daubers out but not restrict flow. Home made screens should not be smaller than the commercial made screen for the particular appliance. If you can't find the larger screen locally it can be ordered through McMaster Carr.
    Stainless hardware cloth
  • I've had the Camco screens on our furnaces, fridge, and water heater since 2008. No problems and no bugs...
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
