nevadanick's avatar
nevadanick
Speed rating answer from Maxxis
On M8008, i wrote and asked them as they say M8008 is a high speed tire. Here is there answer.
To ensure your reply reaches the proper destination, do not modify or remove the subject line of this email.
Nick,
"High Speed" is used to differentiate the M8008 ST Radial from other products we offer that are intended for industrial and/or commercial use, in slow speed applications. The Maxxis M8008 ST Radial carries a "Q" speed rating. However, according to the Tire and Rim Association, the U.S. tire industry specification authority, inflation pressures and load specifications in general for any ST Radial trailer tires without a service description, regardless of the manufacturer, are designed and rated at 65 MPH. However, if the speed is higher than 65 MPH, the pressure and load need to be adjusted according to the following guidelines:
From 66 to 75 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) but requires no load adjustment.
From 76 to 85 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) and load should be reduced by 10%.
We hope this information is helpful. Thanks for your inquiry and interest in Maxxis Tires.
Best Regards,
Your Maxxis Support Team
Maxxis International – USA
Email: MaxxisSupport@maxxis.com | Web: maxxis.com
09/07/2015 20:00
Submission from: Nick
Nick
Address::
State::
Nevada
Region::
North America
Country::
United States
  • I don't really care about higher speed ratings. I travel max 65 mph at all times anyway. Gets me there and back. I'm retired, no hurry.
  • Goodyear had a similar statement about their Marathon tires on their website for years. Obviously 65 mph is a rating not a limit.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
