denverkass wrote:
How do I figure out how to adjust the jaw(s). My Reese 25k hitch, which is the one that Ford sells with the truck, only has one jaw that wraps around behind the kingpin.
As well, do I really need a different break controller from the one that is built into the truck?
So your truck has the factory 5th wheel prep package and you are using the Reese Elite hitch?
I'm using the Reese Elite with the factory hitch in my 2013 F350 and have a popping sound as well. I believe the sound is normal. Check out this video and see if it sounds like yours.
Video
