Gdetrailer
Aug 19, 2019Explorer III
Instead of gooping on a bunch of liquid "fixes in a bucket" consider this..
It is called "PEEL AND SEAL" rubberized roofing membrane with aluminum finish.
You can roll this out and overlap it like rolled roofing except no nails and it STICKS to everything!
Comes in 36" wide by 33.5ft rolls and it took 3 rolls to cover our 26Ft TT.
Can find it HERE for $121 per roll..
You will need to remove everything from the roof like A/C, vents and such then start on the roof edges and roll across the length of the trailer. Do both outside edges first then third run at the center of the roof which will overlap the roofing on the outside edges.
Total time for us was three hrs including vent removal and reinstall.
If you decide to try it, make sure you have good sun glasses and lots of sunscreen, the reflection of the sun is amazing..
Product comes with a 10 yr warranty so you will not need to be any hurry to build a permanent roof..
We still travel and so far this product has stopped every single leak we battled for yrs.. Going on 4 yrs so far and looks great.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
