72cougarxr7
Aug 20, 2019Explorer
A lot depends on the damage, if its a large area, repair is different than smaller sections.
I will assume it is a rubber roof.
If it is a small area, eternabond tape can make a nice repair that will last a while.
If the repair is larger, as long as the decking plywood is solid, you could get some rubber roof material, cut out a patch, glue down with rubber cement, and finish the edges with eternabond.
Make sure you caulk all your vents and protrusions.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
