Gdetrailer
Aug 21, 2019Explorer III
72cougarxr7 wrote:
A lot depends on the damage, if its a large area, repair is different than smaller sections.
I will assume it is a rubber roof.
If it is a small area, eternabond tape can make a nice repair that will last a while.
If the repair is larger, as long as the decking plywood is solid, you could get some rubber roof material, cut out a patch, glue down with rubber cement, and finish the edges with eternabond.
Make sure you caulk all your vents and protrusions.
Honestly, I tried patching worn out roofing, doesn't work.
Fix one spot then another spot, then another spot, then another spot..
You become a slave to that old worn out roof.
Tried slathering on coatings in a bucket, yeah, that didn't work, first cold snap and that coating shrunk at a different rate from the roofing material..
Tried bed liner, yeah, that didn't work, bedliner simply was not able to cope with the expansion and contraction of the roof material and eventually failed.
Lather, rinse and repeat as they say.
Wanted to replace the worn out roof with something a bit more permanent, ROLLED ALUMINUM but was not able to convince any RV shop to order it for me (I have no easy way to handle large truck freight items when delivered) but do have a flatbed utility trailer..
Had ONE dealer out of thirty that I called that made the suggestion of the Seal and Peel product.. That is what that dealer uses and they recommended it.
It isn't going to last like a real one piece heavy duty roll of aluminum but it seems to be well made and made of the same material that the Grace Water and Ice shield (Water and Ice shield is used under house shingles to prevent water and ice dams from getting through to the wood under it) is made of with the exception of the heavy aluminum foil bonded to it.
Note, do not use Grace Water and Ice shield as exposed roofing, it is not rated for full time UV exposure and WILL degrade unless covered with protective roofing..
I did see that you can now get white, if that trips your trigger, but personally I suspect the aluminum faced will be better life in the long run..
This stuff IS highly sticky, especially when applying in summer heat, don't dare let it touch it's self, it permanently and instantly bonds to its' self.
Do note, I did not apply to vinyl, EPDM/TPO roofing, my roof was fiberglass but I suspect it would be fine on those surfaces also as long as the roof has been well cleaned..
Follow the manufacturers instructions for best results.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
