enblethen
Dec 03, 2016Nomad
I have had mine Stay-N-Play for several years. it is the larger older model.
My guess is that you have a vacuum leak causing the pump to run.
Did you put in the check valve? It should be in the line so the vacuum doesn't leak back into the intake manifold.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
