fcooper
Dec 03, 2016Explorer II
enblethen wrote:
I have had mine Stay-N-Play for several years. it is the larger older model.
My guess is that you have a vacuum leak causing the pump to run.
Did you put in the check valve? It should be in the line so the vacuum doesn't leak back into the intake manifold.
Agree about the possible vacuum leak. Turn on the system and see how long between cycles of the pump. If it frequently cycles, you have a vacuum leak. By sealing off the vacuum line, you can determine if the leak is internal in the unit or external in the lines or cylinder.
SMI always gave me excellent advice and customer service so give them a call also.
Fred
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
