FIRE_UP
Aug 28, 2018Explorer
mleekamp wrote:
Thanks for the info....I did not even consider TURN SIGNALS...this is all new to me (toad/dinghy towing) and trying to understand it all.
Thanks much.
mleenkamp,
The first thing you need to understand that no one's explained to you is, contrary to some popular belief, not all cars/toads etc. are made the same. There are some vehicles that when the IGNITION is not in the ON position, if the brakes are applied, the brake lights WILL ACTIVATE. On others, no, the brake lights WILL NOT activate. There is no rhyme or reason as to which vehicles/toads are set up in which manner.
We have two toads. One is an '11 GMC Sierra 1500 4x4 Extended Cab and the other is a '15 Jeep JKUR. With the GMC, the brake lights DO NOT activate when the pedal is applied and the ignition is OFF. But, on the Jeep, they DO activate with the Key in my pocket. So, what does this effect you might ask?
Well, it all depends on whether or not a person decides to use the stock tail lights and bulbs as toad lights. I myself, have done just that for years and years with multiple toads. Many folks run and hide when you mention tieing into the factory wiring to use the factory bulbs for stop, tail and turn. But, it's not rocket science and, to date, I don't think there's been a toad across the entire United States that has burned to the ground because someone's tied into the factory tail lights for toad lights.
This is a matter of opinion and preference. I've never been a fan of adding EXTRA sockets and bulbs in a crowded tail light housing. For one, the socket and bulb are not placed where the back of the housing can do the most efficient reflective action. Only the factory bulbs, in their placement, do that.
Second, unless precautions are taken, there is a high possibility that you will have TWO different signals being sent to the same proximity area and, that's not good for following drivers in traffic situations. By conflicting signals I mean, let's say you've added extra bulbs. Now, you're driving along and you need to make a turn AND stop or slow at the same time.
Well, you put your turn signals on and, that extra bulb begins to flash, correct? Now, you apply your coaches brakes which, also, depending on the style and type of auxiliary brakes in the toad, applies the toads brakes too. When that happens, you'll be sending a brake light signal to the factory bulb, only what, maybe a 1/2" away from the blinking additional bulb, NOT GOOD!!!
There are ways to alleviate this situation but, unless you ask, I won't bother going into them. Just be aware it happens all the time when folks improperly setting up toad lights, are unaware of this. Then there's the same kind of situation where one HAS setup the toads original tail light bulbs as toad lights. Now, again, you're cruising along and need to slow and or turn at the same time. You now send a turn signal from the coach, to the toad, which, starts your toads tail light blinking, correct? But, now you apply the brakes in the coach and, that also applies the brakes in the toad, which, sends a brake light signal from the toads brake pedal, to the toads own tail lights. NOW WHAT? You have two conflicting signals being sent to the same filament.
There are ways to alleviate that situation too.
Scott
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
