RobWNY
Sep 29, 2020Explorer
Stud Finders
I have aluminum studs and want to attach a TV bracket. Any ideas on which brand would be best with density?
RobWNY wrote:Lynnmor wrote:
Aluminum framed trailers may have as few as three studs over the entire length of the side. The wall may have steel sheet metal just under the paneling for attaching a TV and it can be found with a strong magnet. A stud finder for wooden studs will be pretty much useless. If you had a sticker showing the TV mount location then go by that, if you want an alternate location, good luck. Contact the manufacturer if in doubt.
That's the problem Lynnmor, there is a sticker and I've talked with three different people that used the sticker for guidance on the exact same RV that I have and the sticker had been placed in the wrong spot. I'm not drilling pilot holes only to learn some flunkie put the sticker in the wrong place.
wa8yxm wrote:
I recall a device and I ***THINK*** it is the device IU will provide a link to that was advertised on TV a while back that could see through walls. It could not only detect wood/metal studs but things like rats and mice
https://walabot.com/see-through-walls
CavemanCharlie wrote:
I'm a stud will it find me ????
(Sorry, I know this post was not helpful to the thread but, I've always wanted to say that.)
wa8yxm wrote:
Regarding using a magnet to find the fasteners. Aluminum studs one should use aluminum screws (NOTE THE KEY WORD SHOULD, Does not mean they do)
And I'm glad I added the ***THINK*** to the wal-bot )
When I was looking for it I found several competing products
caver wrote:
Project Farm just evaluated a bunch of stud finders.
