RobWNY's avatar
RobWNY
Suburban Water Heater
I emptied my Water Heater today to begin winterizing my camper. When I took out the anode rod, it was pretty bad so I need to get a new one. I guess they are only good for one season. Looking online, I found aluminum rods and Magnesium rods. Which should I buy? Also, I stuck my finger in the tank and there's debris on the bottom of the tank. It feels sandy. It's just near where the anode rod gets threaded in. Is there a procedure to flush the tank better than just letting it drain? IS what I'm finding pretty normal?
  • Thank you Lynnmor, wildtoad and Old-Biscuit. Since I already ordered the wand I'll use it, but I'll also do the Power Flush.
  • Want to really flush out that crud......forget that wand.
    Have to stick it thru hole to use and that partially blocks the drain hole
    Wand is OK to rinse inside of tank walls cause you can point it up and sideways.
    Power flush it....
    With anode rod out stand back and turn water supply ON and let it blast out the drain hole
    Inlet diffuser points downward so the water pressure will stir up the crud on bottom of tank and force it out the drain
    Suburban OEM anode rod is magnesium because it does provide good protection and will dissolve quicker.
    But it can interact with microbes in the water source and stink.....sulfur smell
    Aluminum is an optional anode rod but does not dissolve as quickly hence not as good protection and can be harder to remove due to calcium build up on the aluminum....can even result in 'gel' like substance
    Aluminum hydroxide=====result of the minerals in the water reacting with the aluminum anode rod
    The gel is not harmful..water soluble just drain/flush more frequently
  • FYI Suburban advises to empty the wh when not in use. Should prolong the life of the anode rod.
  • RobWNY wrote:
    Ok. I ordered a Magnesium anose rod and the water heater flush thing from Amazon. Thanks for your help Donn0128 and wa8yxm!
    You bought the right things. Magnesium will offer better protection, but shorter life. The length of time an anode rod will last depends on water usage and the water quality. Expect life of months to years.
  • Ok. I ordered a Magnesium anode rod and the water heater flush thing from Amazon. Thanks for your help Donn0128 and wa8yxm!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If the garden hose is too big they make a smaller plastic "Nozzle" that is about a foot or so long for flushing out the tank, has an angled tip. Any RV place should have.
    As to which type of anode you need. Check with surburan. make sure you have the MODEL number of your heater handy.. I'm unable to advise.
  • Take your garden hose and stuff it in the hole and turn it on. If you happen to have a piece of plastic hose you could make something that screws onto a hose end, but still fits inside the tank and slosh it around to flush out the debris.
    Get the magnesium anode. There is only a few dollars difference, so use the best you can find.
