  • Standard and Crew are the only options on the Ram chassis cabs. Ford gives you the choice of Standard, Extra and Crew in their chassis cabs.
  • So dodge still hasn't put megacab with a reasonable box behind it?
  • My guess is that spacer between the bed and cab is to allow using the 'standard'
    bed without having to design and build a longer than standard bed length
  • They have not come through on that model. I ended up buying a 5500 with crew cab, 9' deck and 52 gallon fuel tank. BTW: Chassis cabs run detuned engines, so don't believe the specifications unless they run the pickup tune in that potential model.
  • mowermech wrote:
    I think that "separation of the truck bed" is a fuel tank;
    "...Mega Cab with an 8-foot bed and an oversized mid-mounted gas tank that combines with a second frame-mounted tank and a third auxiliary tank in the bed for a maximum capacity of 170 gallons. That gives the 6.7-liter Cummins turbodiesel engine a range of around 1,700 miles per fill up."
    Apparently, the writer of the article does not know that diesel trucks don't have GAS tanks!
    170 gallons on board! I would only have to fill that thing every two months!
    Not that I would ever buy one.
    For one thing, it would have been a better idea to build a sleeper in the cab rather than the Mega-Cab!
    I think you're right that it is a fuel tank- but I still think the body should have been seamless. Just looks patched together to me.
    I wouldn't often need filling it. When we're not traveling, I fill up my 35 gallon tank once per month and even then, it's not horribly low. When we are traveling, 600-1,200 miles are common. The range would be nice.
    As for a sleeper vs. Mega-Cab- I bet the delivery drivers would love that. For a family mover like I have (2 adults, 2 kids), I'd love the Mega Cab for the extra comfort for the kids and ability to carry gear in the cab better.
  • I think that "separation of the truck bed" is a fuel tank;
  • That's only a foot and a half or so longer than my truck (crew cab/long bed). I'd love the full air suspension, larger fuel tank, and higher payload numbers.
    I don't, however, like the separation of the truck bed. I think it looks hokey.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
