Grodyman's avatar
Grodyman
Suspension Enhancements for Single Axle Trailer
I have a Passport 153ML, which although a lightweight, is a pretty tall windsail, and sits high on a 5000lb 6 lug axle with traditional leaf springs.
I am toying with the idea of converting it to a torsion axle to smooth the ride and maybe lower a bit. Worth the expense?
I can't seem to find a suspension enhancement product rated for 5000lbs and made for a single axle trailer, all the MorRyde/Equa Flex/etc. are mostly for tandems.
Gman
  • GDS-3950BH wrote:
    Cummins12V98 wrote:
    Personally I like the Dexter Torflex axles, I recently dumped the traditional spring setup on my boat trailer and also added disk brakes with hydraulic actuator. WELL worth the upgrade!!!
    Nice install!
    Having been up close and personal with the frame Keystone uses on the Passport line, I would be skeptical if would handle some shock mounts without a lot of reinforcing. OP doesn't say the year, but prior to 2013 they used a frame made by Dexter, after 2012 Lippert, two different animals there. The Dexter frames were stout, the LCI are recycled soup cans.
    The nice thing about Torsions is the tube acts as an additional crossmember adding overall strength. In the case of the Passport if it is a model with the LCI frame, the OP would want to add a tube to the bottom of the frame rail at least 2" X 2" X 4', probably top to bottom flange gussets inside and out at the end of it, and probably the Dexter 2-3/4" lift bracket between that and the Torsion. I would doubt he can not get enough ground clearance without doing if only counting on the start angle.
    Haylet RV has a good video walk around and you can see that the spring hangers are welded to a 2"x2" tube spacer already.
    I'm not sure the OP can actually lower his TT. Looks like the 2"x2" tube spacer is there for tire clearance.
    Nice install!
  • Personally I like the Dexter Torflex axles, I recently dumped the traditional spring setup on my boat trailer and also added disk brakes with hydraulic actuator. WELL worth the upgrade!!!
  • Shocks, drop axel, depending on the actual weight of the trailer, lower psi in tires
    Springs can also be designed to be softer. Is go with 5-6 leafs vs 4 with the same overall thickness.
    Not sure of tire size. Example, if you have 235-85-16 10 ply tires, go to a 245-75-16 tire. About 1/2" smaller rsdious,, but carry the same wieght per tire. If you're using a 15" rsdious tire, there might be a smaller diam one, or ene a 14" that will carry 2500 or so lbs per.
    More than on way to skin said cat issue.
    Marty
  • I would add shocks - makes a huge difference. I think you will be fine with it after that.
    Lowering it a couple of inches isn't going to make a noticeable improvement.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
