bbells
May 28, 2015Explorer
Ok, I called the manufacturer - Something I always hate doing. This is what he said:
The threads on the on/off handle must bottom out for the sway control to work properly. Loosen the adjusting bolt on the bottom until you can bottom out those threads on the on/off bar. He also added that the factory setting for the adjustment bolt is ten turns after the bolt is started. And, that someone could have lost count at the factory. After the on/off bottoms out, turn the adjustment bolt until it is snug, then give it an additional 1/4 turn. Test it and adjust as necessary.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
