lanerd's avatar
lanerd
Explorer II
Nov 21, 2016
T-Stats in Class A's
Do some Class A's have a single AC/heat pump thermostat for all the AC's or is there a separate thermostat for each one?
Friend of mine just got a 2004 DSDP and says he only has one t-stat but two AC's.
thanks
Ron
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are 3 answers but the short answer is YES.. I will explain
    Some have a single thermostat but two temperature sensors. the Thermostat will show two "Zones" one for each sensor, Normally Zone 2 is the rear. This is very common.
    Some Well.. there is no reason you can't have two Thermostats one for each "Zone"
    and finally technically you could have a single stat control multiple units but.. I've never seen it or heard of it.
    Fact: With a Carrier Air V air contioner The A/C has the ability to control the furnace. and my Motor home one of them did.
    Alas, had to replace it... So I got a 20 buck (includes part of the sales tax) "Mercury Free" heat only T-Stat from ACE hardware.. A Switch from Lowes (nice rocker looks good where I put it) and an LED and series resistor from my Junque box
    Switch on, LED on T-Stat controls furnace
    Tested this AM (power fail took out my Electric heaters) and it worked great.. In fact.. I had issues with the Carrier's control of hte furnace.. No so where I mounted the wall stat.. And once I do one tiny touch up, the job will LOOK factory.
  • Chris Bryant wrote:
    Single thermostat, but it uses separate zone with separate sensors, so temps are set per zone.
    This
  • Single thermostat, but it uses separate zone with separate sensors, so temps are set per zone.
  • Only one in my two Winnebago's but you can set each unit as you would like by using the thermostat
Looking for advice before your next adventure? Look no further.25,188 PostsLatest Activity: Mar 23, 2026
