rockhillmanor wrote:
It is not 'perceived'.
That extra few inches of wheelbase DOES make a difference
I guess that is my point. Everyone states it is the wheelbase that improves the handling. In the case of the Suburban, it must be some other function of the vehicle that makes it a better tow vehicle as the ratio of the rear overhang to the wheelbase is nearly identical to a Tahoe. Therefore based on physics both vehicles should tow very similar.
Just out of curiosity, did you tow with a Tahoe and then move to a 1/2 ton Suburban? I know the post from Crabbypatty lead me to believe they went from a Tahoe to a 3/4 Suburban and saw a difference. But I can tell you that towing with a 1/2 ton Suburban and moving to a 3/4 ton Suburban is night and day as well.
In the end, this probably is a moot point as the OP really needs to be looking at payload capacity if they are truly looking at a trailer with a dry weight of 6300#. Unless it is a family of two, they will most likely be exceeding some ratings in a half ton Suburban/Tahoe.
