Trailblazer87's avatar
Mar 12, 2017
Tekonsha P3 and Electric over Hydraulic brakes
Hello all, new member here and I have a new to me 2004 31' Toymate Toy hauler with a 2016 Chevy Crew cab Duramax as a tow rig. The truck pulls the trailer just fine but with the concern of the electric over hydraulic brakes and the factory brake controller I wired in a Tekonsha P3. The trailer has 3 axles with only 2 of them having brakes.
The problem I am having is when I apply the brakes the brake controller flashes red and shows an overload, this happens about half the time I apply the brakes. When this happens it feels like the trailer is over braking. I have watched the controller and it happens when it goes over 4.5 amps.
The settings I am using are Hydraulic, the medium setting as the trailer weighs 9000 lbs when unloaded.
Any help would be appreciated. Thanks.
  • You might call Technical Service, 800-632-3290 to see if they can help you - another option at least.
  • BenK wrote:
    Is the factory trailer brake control disconnected when you installed the P3?
    If not, then maybe both are trying and confusing each other
    I disconnected the blue wire for the factory unit and ran a new one for the P3 like in the installation guide.
    I tested the manual brake lever on the P3 while sitting still and it ran up to 14 amps no problem, you can hear the hydraulic motor on the trailer tongue activate and apply pressure.
    I need to get to the bottom of this because we are planning a 3500 mile tour of the western US in June. So not too much of a rush. I appreciate everyone's input on this.
  • Is the factory trailer brake control disconnected when you installed the P3?
  • Thanks, just asking to make sure. If we don't see a few more comments on this I'll move it to the Towing forum to see if others there might have some advice.
  • Yes the controller is set for hydraulic. I took the trailer back to Bill Wyrich after I bought it last year so he could go through it stem to stern. They replaced the wheel bearings and checked the brakes while they were at it. Also checked all the appliances and corrected a wiring issue with the Clearance lights. I have the controller set for the boost level 2, level 3 locked up the tires on first application of the brakes and level 1 wasn't enough.
    This isn't the first bit of heavy towing I have done but a first time experience with this type of trailer brake system. I'm used to the more conventional electric trailer brakes like what we use on the ranch.
  • Trailblazer87 did you set the controller brake type to Hydraulic? I know the P3 has a lot of settings, just making sure you've gone through the instructions carefully. Between the brake type, adjusting the power and boost can all play a factor.
    Have the brakes on the trailer been inspected? With an older rig that could be another issue.
  • Blackdiamond wrote:
    So are you saying the trailer has hydraulic brakes??
    If not the OL on the controller is most often a bad wire or a worn magnet on the electric brakes.
    Yes it electric over hydraulic brakes. I will do a continuity check on the controller wiring. Thanks for the help.
  • So are you saying the trailer has hydraulic brakes??
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
