secretcheese300's avatar
Sep 22, 2016
tell me about your toilet!
Hi all! I haven't posted in a long while. I need some toilet talk. :) We have a Dometic 310 and I'm tired of how nasty the inside (below the flapper) gets. Is there a toilet out there that has a different cavity design (I'm thinking maybe a shaft that extends all the way down to the flange, something easy to clean with the toilet brush )? The Dometic's flapper arms and molded cavity get totally mucked up, and now I'm doing a vacation rental and I'd like each new guest to not get a reminder of the last guest, so to speak.
Or do I just need to clean the cavity and flapper arms every time? I have found that it is very easy to knock off the flapper assembly with the toilet brush. And then your hands have to go down inside there. You know.
First world problems. :)
Thanks,
AC
  • I have a Sealand porcelain unit that has a large "ball valve", not a flapper. The contents drop straight down for about 8 inches, then make a slight turn into the tank. It doesn't collect unwanted stuff under the valve.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
