TheNorcoldGuy
Jun 22, 2016Explorer
You're right about the fans, although the Norcold 1200/ 1210 does have two fans mounted at the top. If those fans aren't coming on at all and you're in a warm climate, you probably have either bad fans or a bad fan thermostat. You can get to the fan thermostat from the roof vent. Try bypassing it to see if you can get the fans to come on. If they come on, you know that the issue is your thermostat.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
