CarnationSailor
Jun 25, 2016Nomad
TheNorcoldGuy wrote:
You're right about the fans, although the Norcold 1200/ 1210 does have two fans mounted at the top. If those fans aren't coming on at all and you're in a warm climate, you probably have either bad fans or a bad fan thermostat. You can get to the fan thermostat from the roof vent. Try bypassing it to see if you can get the fans to come on. If they come on, you know that the issue is your thermostat.
The fans seem to be working as expected, and we have not been in really hot weather. Highs in the mid-60's to low 80's.
Since my original post, the temp has once again risen to 43 and then dropped off to 34. As before, this happened with very little opening/closing of doors. It still seems to me that the thermocouple and/or control circuitry is just waiting too long to react to rising temps inside the box.
I called Norcold customer service, but gave up after being on hold a long time.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
