Reisender
Apr 25, 2021Nomad
Gjac wrote:Reisender wrote:When you say 26 to 45 cents do you mean per KWH?Horsedoc wrote:
Not one answer to the questions that should be on everyone's mind..
How long to charge a heavy duty truck?
What does it cost?
If this place saves on petro chemical fuels, where does the energy come from that generates the power to do the charging?
Well, the article mentions a 1 megawatt rate which is about three times faster than at currently available vehicle charge stations. But that is changing fast. So assuming the 1 megawatt is achievable probably a couple hours for a 1 megawatt pack. Who knows.
Cost at current fast chargers is around 26 cents to 45 cents so multiply that by the pack size and go from there. It costs me 8 bucks to fill up at home, around 20 bucks to fill up at a supercharger. If a truck has a pack 10 times bigger than mine at those rates about 200 bucks.
Where the energy comes from depends on the country, region, province, state etc. In our province it’s from Hydro. Etc etc.
Not an expert. :).
Yes. Per kWH. Superchargers are typically 3 times as expensive as home charging. Public DCFC from other companies can be even more. Which is why the vast majority of charging is done at home. Generally fast charging is only done on road trips. Keeps the fast chargers from getting overwhelmed that way.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
