ol_Bombero-JC
Jun 11, 2014Explorer
wa8yxm wrote:
Having been something of a ladder monkey in my youth.. I would say "GOOD" to an RV with no attached roof ladder, in fact I cut mine off, Here is why:
1: The standard RV roof ladder is a featherweight,,, Now.. a 10 year old it might hold but 300 pounds of sixty year old.. NOT A CHANCE of it holding up the way they mount them.
Second, it is a vertical ladder, very hard to climb, not a bit like a slanted ladder that I used professionally when I did roofing for a living.
What would I recommend,, or to be more precise what do I use?
Well, many moons ago my Dad (May he rest in peace) got a convertable step/extension ladder from Sears. That is what I use when I need to get on the roof as it is long enough (Just) to be a proper roof ladder, Way easier to get on and off and to climb,, But you do need to be careful that it does not blow over unless you have a ground crew.
It also comes in handy (Step mode) for washing and waxing.
For lesser jobs I may use my Telescoping ladder. it is NOT long enough for use as a roof ladder.. but it is still very handy. Collapsed it will fit in at least one suitcase I have. (Provided I remove the portable recording studio first).
Excellent advice and observations!
Spent 30 years climbing ladders.
"Modified" for RV use:
A proper "climbing angle" is to stand at the base of the ladder, when you reach out to the ladder a rung should be at (approx) arm's length away from you - at shoulder height.
Which means the base of the ladder is about 5-6' away from the RV.
If you have a "spotter" (assistant), he/she can stand behind the ladder holding (pulling back on) both ladder rails - or stand at the base with one foot on the bottom rung - firmly pushing inward on the rails. Really important for starting down!
The ladder attached to the RV obviously does *NOT* meet that standard - along with other "failings" - like the attachment/s to the RV.
You don't want "failings" - to turn into "fallings"!.:(
(Neither do I, and I'm 72)
On "the road" if I need one, I use a telescoping ladder - tied off to top of the stationary ladder.
At home I use an extension ladder - also tied off at the top.
(Either one - extended one or two rungs *above* roof level).
IMO - that's all the attached ladder is good for - I *never* use it.
For the RV with no ladder, I would look for (or add) an anchor point to tie off the ladder to the side - close to the top of the RV.
*If* there is also a slide on the *side* of the RV, the slide extended to block one side of movement would be good also.
The roof of an RV is a good place to avoid - if at all possible!.;)
