Cecilt's avatar
Cecilt
Tinting TT windows
Our new TT came with night shades. We are considering tinting the windows or replacing with day/night shades. What we want to accomplish overall is privacy during the day, less heat inside and still maitain a view outside. I came up with pros/cons:
Tint:
1) Can see outside(albeit slightly darker but no one will see inside during day from the outside). No curtain needs to be down during day.
2) Less heat intrusion so TT stays cooler and AC works less
3) I can do all my TT windows for $250 installed by a professional
Day/night shades:
1) With day shades down you really can't see outside at all but it does give you privacy
2) More prone to break due to opening and closing of them
3) Would cost about $650 to do the same windows so $400 more.
We are leaning toward the tint. Installer left some samples today. One was a limo 5% tint. Looked good from outside as it matched the current window color and you could still see outside. Another was a more reflective tint so the outside looking in had a slight mirror look. This tint was a little lighter on the inside as you look out.
Anyone have a preference if you installed tint and if you like it. tks
  • Decided to go with 5% limo tint. Excellent privacy and still good viewing outside even on cloudy days. We have night shades so will pull these down at night. Tks for the replies
  • My Cardinal has window tinting as well as day/night shades. Even with all that it's still pretty bright in the camper during the bright summer early mornings. To combat brightness in our bedroom my wife made some blackout curtains. We found some black fabric at a fabric store that we held up to the store lights to make sure no light got through. She sewed some hook & eyes into the fabric and onto the fabric valances above the window. We also made a cover for our bedroom vent using Velcro to help attach it to our vent frame. It's very dark in our bedroom now and nobody can see through the windows.
  • SWD wrote:
    I've done the window tinting on our old trailer. Yeah it kept the temps down a bit but not as much as night/day shades. We have those on our current trailer and find that they are far more superior at keeping the trailer cool than window tint.
    Use a good film and you'll block 40 to 50% of the heat and yes to the night shades, they will be needed at night when you have the lights on.
  • bradnailer wrote:
    If your trailer has double pane windows, you might check to see what kind of tint is acceptable for them. I've been told that mirror type tint can create heat between the panes and cause failure. But this could be incorrect as well.
    no you are correct.
    bumpy
  • dbbls wrote:
    You will still need some kind of shades for night because you can see inside at night when the lights are on and it is dark outside.
    That statement is VERY true. Our new Wildwood Lodge destination trailer came with tinted windows BUT the patio door was NOT tinted. So I went to Menards and bought window tint. Wife and I applied it ourselves to the patio door.
  • You will still need some kind of shades for night because you can see inside at night when the lights are on and it is dark outside.
  • There are many different kinds of tint depending on what you want to do.
    There are some HIGHLY reflective tints on the market. It's been a few years but when I checked into tints for my house I found out there is some really reflective stuff on the market. I forget the % of reflection but there were some good ones on the market.
    Nothing wrong with doing both if you have the $$$'s. That is what I'm doing for my house. :)
  • If your trailer has double pane windows, you might check to see what kind of tint is acceptable for them. I've been told that mirror type tint can create heat between the panes and cause failure. But this could be incorrect as well.
  • I've done the window tinting on our old trailer. Yeah it kept the temps down a bit but not as much as night/day shades. We have those on our current trailer and find that they are far more superior at keeping the trailer cool than window tint.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
