scottykrug
May 01, 2016Explorer
Had one shackle on my last trailer that had to be jacked up to grease. The hole in the wet bolt somehow lined up wrong with the bushing and the pressure of sitting normally on the ground stopped up that hole and stopped the grease. Solution was to either remove the bolt and rotate it 90 degrees or simply jack the trailer and grease. Due to simplicity I chose the latter for the short term. Sold the trailer before I was able to rotate the bolt.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 17, 2026
