dcmac214's avatar
dcmac214
Tire Pressure - MAX vs DATAPLATE
A LOT of replies to tire threads recommend running the trailer (and I assume also car/truck/motorhome) at sidewall max psi instead of the dataplate psi. Why?
My trailer tires have a max psi of 120. The trailer dataplate tells me the correct psi is 80. So I follow the manufacturer recommendation 80psi. I figure they know better than anone else what's 'right' for my trailer.
What benefit(s) would I get running sidewall max 120psi?
Same with my car & truck. Dataplate psi is about half the sidewall max. There may be a noticeable savings in fuel mpg running tires at sidewall max but the ride would probably be so hard as to be quite uncomfortable and I would assume tread wear would be much quicker. And I'd also assume there would be problems with the tire maker if I tried to make a warranty claim while running sidewall max instead of vehicle dataplate psi.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 05, 2025
