riven1950
Dec 14, 2016Explorer
tire pressure question
Just put Michelen lt tires on my 2013 f150 4x4 cc. Max pressure is 80 psi. E rated.
My question is what would be a good pressure to run when not towing or hauling? What do you folks do?
Door jamb calls for 35 psi, based on original P rated tires, same size. ( 275/65/18 )
Seems 80psi is too much and 35psi is too little for normal driving.
Also, is full 80 psi what you folks do for towing? Should front and back be different?
Towing a TT about 6000-6200lbs loaded with wd hitch/ sway.
thanks, bought tires at Ford dealer and they are not much help.
