brianosaur
Mar 27, 2018Explorer II
downtheroad wrote:
A good bed of gravel (like you have) should be good enough.. Should drain and prevent standing water.
If want you can also use a Lynx Leveler under each tire to get them up some off the gravel...Lynx won't rot or retain water...probably better than composite (Trex like) boards....
Okay good idea.
So the big no-no about parking on concrete, that's different from gravel, is moisture? I thought it was some weird chemical reaction thing between rubber tires and both concrete/asphalt.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
