bpounds
Oct 24, 2019Nomad
cummins2014 wrote:
...wonderful OE tires that are worn out in less then 30K...
You've mentioned that a couple of times, so I guess you've had very bad luck with OEM tires. That has not been my experience at all. In fact, as often as not, I replace the original tires with the exact same tire, and I've done that for cars as well as trucks.
I might expect that if the truck/car I bought had the base trim level tires, which often are the smallest rated tire the designers anticipated. I never buy that version of a vehicle, so maybe that's why my tires do better??? :@
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
