gtnsmlr
Feb 08, 2022Explorer
Over the years of full timing, I've replaced all the parts on mine a number of times. the water valve, if needed is a simple fix. I've noticed that the valve Is prone to leakage if the water pressure is low, give that a check. If you have access to the pedal side you can replace the valve parts without removing the toilet but for the first time pull the toilet, getting the peddle back on is a chore and best done o n the table with a beer. I actually like the style ll, you can rebuild all the moving parts in 15 minutes once you get it out.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
