Baja_Man's avatar
Baja_Man
Tongue Jack Block - Need one light, strong, and tall
I would like to have a tongue jack block that is light, strong (2000# TW), and at least 10" tall.
I need the height so that I can raise my tongue/coupler pretty high to make it easier to "unload" my weight distribution bars on my Blue Ox BXW2000 Weight Distribution Hitch.
I know I can stack the yellow blocks, and this is probably the less costly approach. It would be nice to have a single dedicated unit that I can use at home when stored and at campground.
I have made one of wood (10" tall) but it was much heavier than the yellow plastic ones even stacked to reach 10" tall. I can always make another one out of wood if it appears that this may be the best solution.
Thoughts, suggestions, etc?
Thanks!
  • Also found this one for $25 by Andersen hitches, 8" tall and 2000# rated.......
  • Not quite 10", but there's this Valterra one. If going tall, the wider you can make the base, the more stable it will be. I don't think you can buy ones with a wider base though.
