herbhyde's avatar
herbhyde
Tongue Weight
I am trying to set up a new cargo trailer to tow behind my MH. The MH is a 2006 Kodiak Dutchmen 34G(Duramax).It has a 2 1/2 inch receiver and 7000 lb tow capacity. The trailer is a Covered Wagon 7 X 14 with a 2 foot "V" and weights 2560 lbs. It has TWO 3500 lb leaf spring axels and 225/15 ST tires. With the trailer sitting level and empty there is only 200 lbs on the hitch.
Is this normal??
The way it pulls, you would not even know you are pulling anything.
  • Turtle n Peeps wrote:
    After designing and building a few trailers in my time I will tell you that this trailer will not tow well at all unloaded and you will have to put as much weight you can forward to get it towing well when loaded.
    If you don't load as much weight forward you you will have a trailer that does this going down the road.
    Guess you missed the last sentence in OPs 1st post
    No, I took that as: "I have enough HP to not even know it's there." Did I take it correctly? I have no idea?
    I know this, I've towed a lot of tongue light trailers in my time and every single one of them tow like the video I posted, and worse. I've seen too many people put the heavy part of the load in back of the CG and that didn't work out too well for them.
    That being so, I would load the trike backwards to get as much weight as forward as possible.
    When I got the trailer, I brought it home behind an ACADIA DENALI.
    Other than lousy gas mileage, the trailer pulled straight(NO SWAY).
    The TRIKE will have the front wheel in a CHOCK, so loading backwards is not practical.
    I will put more weight on the TONGUE and the chock is adjustable forward and back about 6 to 8 inches.
  • What you need to do is load the trailer so it ends up with 12.5% for a loaded tongue weight! so with 4500lbs loaded you will want a tongue weight of approx. 560 lbs. you`ll have to move your stuff around until you end up with that amount. and maybe mark the floor so you know where the trike goes every time it goes in.
  • Maximum load in the trailer will be under 2000 lbs.
    A Goldwing TRIKE and some equipment.
    Thank you for the quick replies.
  • Travel trailer axles are proportionally closer to the middle of the trailer body than a utility/cargo trailer like yours. With the axles further to the rear, less tongue weight is necessary for a stable tow, especially with the trailer empty.
    Empty is as evenly loaded and as low of a center of gravity as the trailer will ever have. RV trailers are often heavily biased to one side or the other due to the kitchen being along one wall, and their center of gravity is much higher.
    You are not disproving any laws of physics here. Rules of thumb are hardly absolute, and the 10-15% rule is just a rule of thumb.
    What you will find is that as you load the trailer, the tongue weight will probably end up well over 15%. This is not a big deal either. There's only so much space in the trailer and most of it is between the axles and the truck.
  • All depends on the design of the trailer and axle position. Tongue weights on utility trailers will vary based on designed purpose and are not always the same as a campers' 10-15% average.
    Load it up. If it tows fine and stable the low tongue weight shouldn't be a problem.
  • thats about 8% of the trailer weight. I suppose your axles are evened out well if 200lbs is the actual tongue weight
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
