JRRNeiklot's avatar
JRRNeiklot
Too much weight on tongue?
I just bought a new (to me) travel trailer and I'm in the process of getting my solar setup installed. I need help with weight issues. The trailer weighs 3500 lbs dry, and 3980 with a full load of water. I'll be pulling it with a 2004 Tahoe with a GVWR of 6800 lbs. The curb weight is 5133 lbs. I can't find the GCWR on my truck,but an online search listed it at 10,000 lbs.
My question is, can I stick 4 Trojan T-105s on the tongue of this trailer and still pull it safely? That's gonna be 248 pounds, minus the 60 pounds of the Exide battery currently there, for a total of 188 pounds.
Thanks for any and all advice.
    Probably be OK as the truck can pull around 7400 - 7700 lbs.
    But its the weight on the rear axle that you should be concerned about..
    We can all guess here but the right way is to fill the truck with fuel, and all people and gear to go camping. Then get the truck weighed.
    Get separate axle weights. Take the axle rates from the door tag and subtract them from the scale weights.
    That will tell you how much payload you can put on the rear of the truck..
    Are you going to use a weight distribution hitch? You should IMO...
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
