CloudDriver
Apr 23, 2017Explorer
Here's my $0.02.
A torsion bar and a coil spring are two versions of the same thing, assuming the same material of construction,heat treatment, etc.
Visualize it this way, a torsion bar twists when acting as a spring. A coil spring is just a torsion bar that is wound into a spiral. When a coil spring is compressed the metal that makes up the spiral gets twisted. If a torsion bar has the same spring rate as a coil spring, the axle will go up and down the same amount.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
