Wild_Card
Apr 23, 2017Explorer
CloudDriver wrote:
Here's my $0.02.
A torsion bar and a coil spring are two versions of the same thing, assuming the same material of construction,heat treatment, etc.
Visualize it this way, a torsion bar twists when acting as a spring. A coil spring is just a torsion bar that is wound into a spiral. When a coil spring is compressed the metal that makes up the spiral gets twisted. If a torsion bar has the same spring rate as a coil spring, the axle will go up and down the same amount.
He is talking about leaf spring not coil springs.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
