JoeH
Aug 10, 2021Explorer III
Berkyeng wrote:JoeH wrote:
The Blue Ox base plate for my F150 ( 2015) replaced the tow hooks. Just remove the tow hooks and bolt on the nubs for the tow bar attachment. No modification of anything on the F150 .
Looking at the installation videos online I would have to remove a significant amount of the front bumper and grille assembly. Hence I’m interested in the setup that simply attaches to the factory mounted tow hooks.
I've spent more time ( almost) just typing this response than it takes to remove the trim and bumper and replace, trim pops out , held in with plastic tabs, the bumper is held in with 6 bolts. remove the tow hooks, the base plate bolts into the space vacated by the hooks and the base plate has a couple supplemental bolts that you need to enlarge existing holes in the frame. It also has a safety cable. to wrap around the frame. Total time to install is maybe an hour ... and that includes a beer or two !
I installed mine in 2015 right after I bought the truck. I've towed 40,000+ miles.
When you're done with that, then install your supplemental brake system. I went with an M&G. Probably took another hour or so to install. I installed diodes on my tail lights and ran wires along the frame to a round 4 connector I put by the base plate mounts.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
