LocoMike's avatar
LocoMike
tow/haul light flashing,,but didnt feel any problems
So coming home yesterday from our camping trip the tow/haul light started to flash. this was about 40 miles into the trip. So we pulled over, the tranny fluid looked low, so I added alittle more. The light stopped flashing, but maybe another 20 miles it started again, we pulled over and it stopped. We got to a rest stop and after about 20 minutes, I called Good Sams Roadside, there tech said to take it out of tow/haul mode and so we left the rest stop and it was good for just about 40 miles. We hit another rest stop, at this point we were about 80 miles from home. I did not feel any difference in the truck shifting or if it was acting different. The light flashed again, sometimes going off, then coming back on. We hit two more rest stops, letting the truck rest. We left the last rest stop, we were already halfway up a big hill on the Mass Pike and after 5 miles the light came on, but then after a few miles it stop and from that point to my house ( which was just over 50 miles) it never came back on.
The truck is a 2006 F250 gas that just hit 100,000 miles. New motor put in over the winter and a few years back had the cam phasers and some work done on it.
Could this be some sensors, etc that is starting to go and needs to be replaced?
  • Have your codes read and checked against the OEM look up tables...
    OBTW...by the time you 'feel' something...it will most likely cost way more then
    fixing it BEFORE you can feel it...
  • It could be anything. You need to have the codes read. Even something simple like a speed-sensor fault or loose connector can trigger a fault.
  • This could possibly be your tranny overheating, I had a similar problem and it turned out my cooler had gotten blocked. Moved the blockage out of the way and havent seen the flashing since. The only problem when you take it in to get checked out is there is a possibilty that they wont see the code to determine what is wrong if it is not flashing when you take it in.
  • There is a ton of information on the google about tow/haul light flashing on a Ford F250. It's not encouraging, with many indicating that the transmission will not engage or shift.
    You should probably take it to a reputable transmission repair shop for analysis and repair.
