Searching_Ut
Nov 08, 2015Explorer
Every truck I've ever owned has either been purchased with a limited slip or I did an aftermarket install. The only problem I've ever had is that if you do get stuck, you're really buried and end up sitting on the differential, tow bar etc. You'll have your work cut out for you to get out of the mess. That said, you're a lot less likely to get stuck, especially if you don't do stupid things.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
