mkirsch
Feb 26, 2016Nomad II
DirtyOil wrote:
As a transporter of RVs I find the "advertised" UVW weights to be spot on according to DOT scales I have to report to.
There are a couple of manufacturers who run their trailers across a scale at the end of the assembly line and stamp the actual as-built-with-options empty weight on the VIN placard.
You must transport for one of those manufacturers, and consider "advertised" weight as what's stamped on the VIN placard.
We're talking website/brochure numbers here. There's no possible way the brochure numbers can be accurate because not every example of a particular model of trailer is equipped the same.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 17, 2026
