brioux1's avatar
brioux1
Towing Advice
I am looking at buying a new TT and want to make sure I am looking at models I can tow safely and easily. I understand I will need a Weight Distributing Hitch. To be honest I've had a hard time getting a clear answer on this from TT dealerships or my vehicle dealership. Every time I enquire I just get the "Oh your fine, you can tow anything" answer. This isn't sitting well with me so I thought who better to ask then real RVrs. I know its all about the specs of the tow vehicle so I will do my best to provide this below.
2014 Ram 1500 Big Horn 5.7L Hemi w/ Tow package Crew Cab 6'4" box
From The Sicker on the door:
GVWR 6800 LB
GAWR Front 3900 LB
Rear 3900 LB
Info- Tire and loading
combined weight of occupants and cargo should never exceed 1070 lbs. (this one confuses me)
From Manual:
Towing- 10,000 lb.
Payload- 1520 lb.
If I have left out any relevant info please let me know. I am a little new to this so I may have missed something.
Finally, I will be traveling with my wife and two young children. Basically I just want to know what weight of TT I should be looking at.
Any help will be much appreciate
Thanks
  • Agree with Lynnmor, a 5K loaded trailer wt will be about it due to low payload of 1,070. At 5K, you will have 600+ lbs tongue wt. That only leaves about 400 lbs for everything else in the truck.
    Your engine/driveline is designed to tow 10,000, but with a GVWR of only 6,800, you simply don't have the payload.
    Similar trucks may have 1,520 payload, but the sticker on YOUR truck indicates 1,070 payload as it left the factory, before going over GVWR. This has to do with options added to YOUR TRUCK, options add weight.
    Some choose to go over GVWR a little, but stay under RAWR of 3,900.
    Hope you find a nice trailer, that works for you!
    Jerry
  • The only numbers that are useful off the door sticker are GVWRs (front, rear, and total)... and then only after you've weighed the truck fully loaded (passengers, fuel, hitch, pets, and all the junk you'll go camping with). Subtract those scale weights from the GVWRs on the door sticker and you'll have your real payload numbers. With most 1/2 - and 3/4 tons, for that matter - you'll run out of rear axle capacity before you hit the maximum towing limit. Also use the GVWR on the trailer - not empty or factory weight - and calculate 12 - 14% of that for a loaded tongue weight. Finally, and only after you're within the specs of the tow vehicle, proper setup of a good WD hitch with anti-sway will put the icing on the safety cake.
    Rob
  • combined weight of occupants and cargo should never exceed 1070 lbs
    You say "this one confuses me," so let's try to make it a little clearer.
    What this means is, the total weight of everyone in your truck, plus anything else you have in the cab or bed, plus the weight of the trailer tongue should not exceed 1070lbs. This includes accessories such as bed toppers, bed mats, running boards, and stuff like tools, roadside emergency equipment, etc..
    1070lbs is VERY low for a payload rating. You must have a truck with every option known to man on it.
    If you have your wife and three linebacker sons in the truck with you, you could easily eat up that 1070lbs before you even hitch up.
    I'm just stating this so you have the information to know how to go "by the book." You can always throw the book out the window if you want. HOWEVER, I really don't think you should shoot for a 10,500lb trailer because you simply won't be happy with the performance.
    Standard BS salesman line.
    Deduct the passengers and cargo from the 1070. The result would be the maximum hitch weight.
    My guess is that you will need to stay under 5000 max trailer weight.
