concord_05's avatar
concord_05
Towing Ford Flex
Have a 2008 Four Winds Chauteau and until recently towed a 2002 Saturn. Husband decided it was too hard to get out of so have set up our Ford Flex with a ready brute tow bar with surge brake. (. We had used it several years ago on another vehicle) the Saturn had a totally different set up. The Flex sets up much higher so ordered a 4 inch raised hitch, exstended, because of the way the back of the motor home is made. Even with the extended hitch it wouldn't fit and had to buy an extension hitch. Put it all together today just to test it out. Pulled our car easily and surge brake worked perfectly . Still have some concerns as it seems to have some sway to it. Plan to reorder another raised hitch and get shorter one. Also going to work on tightening where pins hook it together. Maybe bolting it. Looking at it in the rear view monitor it just looks so different from our Saturn hook up(. Had bar across front of grill, so no play at all). This could be normal. Hitch height is even, wonder if it will change when loaded. Lots of Rambling thoughts, any input would be greatly appreciated.
1 Reply
  • Not knowing.....is the Flex (according to the owners manual)able to tow 4-down? If the book says "no"...you got a problem.
    You say "sway"...do you mean the Flex doesn't track straight when being towed? Something is wrong...better find out, and fast.
    If you only THINK the Flex is not tracking straight...as viewed from the motorhome mirror(s), I suggest you hook up the Flex, have hubby take the mh for a ride...and you follow in another car. SEE if the thing is really (or not) tracking straight.
    Go from there...and g'luck!
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 07, 2025
