kfp673's avatar
kfp673
Explorer II
Sep 27, 2017
Towing full size P/U with Class C or gas A
Hello All,
Thanks in advance for any help you can offer. We currently tow a travel trailer but are looking to move to either a class C or gas class A. My concern is that I still want a truck. Whatever vehicle I tow is also my daily driver when at home and I have use for a P/U. I considered getting something small like a canyon but we have 3 kids. 5 people in a compact truck is not comfortable. A crew cab 1500 works great. Seems like they weigh in around the 4500-5500lb mark. Is this possible to tow?
So is anyone towing a 1500 crew cab with a gas motorhome? Any thoughts? does the MH pull it ok?
To answer questions ahead of time, the reason for us wanting to reverse the way we tow (motorhome towing truck instead of truck towing RV) is a few reasons. First is we have been taking a few longer vacations and trips and the travel would be much easier on the family. Second is there are plenty of times when a second vehicle is not needed such as music festivals, tailgating, skiing, and other actives we like. But any time we are camping or on vacation we really need the truck to help us carry our kayaks, get us around once we get to where we are going (many state and national parks), and just simply be our vehicle.
Thanks again!
  • Almost all Class C motor homes have a 5000 lbs towing limit. However it may be even less as the limit is determined by subtracting the actual weight (after loaded with equipment, food, clothing, people, animals) from the max gross weight of the motor home. In many, many cases the towing limit will be less than 5000 lbs.
    Some Super C motor homes will have more than a 5000 lb limit.
    Some gas Class A's will fall into the same category. I think all diesel Class A's have a 10,000 lbs (or more) towing limit....again can be less depending upon the "actual" loaded weight.
    Ron
  • I see them and towing Tahoes too. What is the towing weight limit on the MHs you are considering? And doesn't a crew weigh 7,000 pounds or so?
