I am going to tow my Honda Fit and the owners manual says to remove the 30 amp radio fuse so as not to drain the battery while towing. The fuse is not easy to get to so I was wondering if I installed ...
If your braking system needs 12V then a battery disconnect is probably not a good idea. A fuse switch or a charging line (like the ToadCharge) are better solutions.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
