SG223's avatar
SG223
Towing speeds with leveling / sway bar set up?
I've been towing for years now, but generally always towed enclosed trailers behind motorhomes (we race motocross). However, we are looking at moving to a truck / toy hauler set up, with a 2014 F-350 and a trailer with UVW of ~10k lbs. With bikes, gear, tools, and the trailer loaded, I'm guessing we'll be pushing 12k+ lbs.
I'm obviously going to have to use a leveling / sway bar set up, so a couple questions:
1) The dealer recommends the Husky Centerline system, any good / bad feedback on that set up? Are there others that are easier to use, more reliable, etc? I've read several posts that reference Blue Ox, how do they compare?
2) With this kind of set up, what kind of towing speeds are folks pretty comfortable with? We race motocross and typically run in the 68 - 70 mps range (just under 10 over posted speed limit). Is this trailer going to be swapping all over the place, even with the sway bars?
I've never towed such a long / heavy trailer behind the truck, and am curious whether this kind of driving is going to be problematic? We currently tow a 14' enclosed trailer (1/2 the length and probably less than 1/2 the weight) with just a sway bar and have no issues.
I'm sure many will say to "slow down", but we drive so far, and get out of the track so late, we're always pushing it. If we can't run this kind of pace, I may go back to the motorhome / trailer route.
Thanks in advance for any insight / experience you can share.
Scott
  • Scrap the cheap Husky hitch and go with a good name brand such as Reese, even better is the Reese Straight Line (Dual Cam) which has built in away control.
    With that said why not get a 5th wheel. Inherently much more stable and will tow better than a TT.
  • I tow a 35ft (bumper to ball) TT that weighs anywhere from 9k to 10k with a 2015 F-250 with overload springs (so basically a F-350 now) and BlueOx Sway Pro. 70mph is my standard speed and it rides great.
  • I tow a 20' enclosed trailer weighing 6000-8000 lbs behind a truck carrying a 4000 lb truck camper. Because of the truck camper rear overhang, I have 28" extension off the receiver. This tows fine at 65 mph with weight distribution and no sway control. The first truck was a Ford F250 and now it is behind a Ram 5500. You can look at my profile to see trailer details. If you plan to tow faster than 65 mph, plan on upgrading to higher speed rated tires than the typical ST's I run.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 20, 2025
