JRS___B's avatar
JRS___B
Towing Std. Shift RWD Car - Unhook the driveshaft?
In the future I will need to tow a 1989 Mustang GT from MI to FL, just once. I have read that it can sometimes be difficult to get this type car on a flat bed trailer because of the low clearance and ground effects.
So I figured a front wheel dolly might be the answer.
My question is whether or not I should drop the drive shaft when using a front wheel dolly.
I am thinking with a manual transmission that just leaving it in neutral would be enough. For what it's worth, this particular manual transmission uses automatic transmission fluid instead of regular gear lube.
Any suggestions would be appreciated.
Moved to Dinghy Towing forum from Towing.
