Terryallan
Apr 13, 2021Explorer II
Refer to your owner's manual for the process of setting up your hitch with the auto level. I had one, and the instructions went as followed.
Take it to a level parking lot. Uh hook. Leave the vehicle running and let it level itself. Then before it can lower itself. Turn the auto leveling OFF. The vehicle should stay level, and not lower.
Then adjust the hitch as you normally would. I use the tape measure method. I get the front end back down to where it was unhooked. That will put any lost weight back on the front axle.
after you get the hitch setup with the leveling off. Turn it back on. It should not raise the rear high enough to change the weight transfer. If it does. the front will be high again.
That was my instructions, and it worked well.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
