Grit_dog
Apr 13, 2021Trailblazer
Durb wrote:
If you can, disable the auto air bags and use the WDH to level your vehicle. If your auto level lifts the rear of the truck after your hitch has been set up it will serve to unload your front tires and possibly defeat the anti-sway capabilities of your hitch. Both scenarios make your tow worse and possibly unsafe.
Doesn't work that way. Can't just turn it off on a Tahoe.
It's not much different setting up an an auto level system with weight distribution, just cant use a tape measure. Either scale or trial and error until it "feels" right. The ride height will just remain the same.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
