starcraft69's avatar
starcraft69
TPO roof not coming clean
I am looking for some help in how to get my TPO roof clean. I have a 2015 jayco Eagle HT and cant seem to get the roof clean. I have used mild soap with brush, pressure washer, hand brush. It still has stains from leaves and from boots when on it wet and dirty. What can i do to make look new again?
  • Thank you all for your input. I do wash a few times a year. I will just have to learn to let it go.
  • A cheap spray cleaner with bleach from the dollar store will bleach out the stain color.
  • I used to use Simple Green once in a while, as I recall it worked well.
  • If you can find it.
    Xtra Duty C made by Apter Industries.......that will clean it like the day it was made, but its really strong stuff and you have to dilute it a lot and be really careful. Wet the roof, dilute the super C 50/50 with water in a small spray bottle and spray a 3 x 3 area at a time, let sit for 30 seconds, a quick brush and rinse with lots of water. Do not let it dry on the sidewalls. Do it in shade.
    Once clean keeping it treated with 303 every 6 weeks or so will make it much easier to clean the next time. Buy a gallon of it and use a sponge mop and a 10' step ladder. It takes 15 minutes max. Dont worry about cleaning it. The 303 will stop a lot of stuff from sticking until the next yearly cleaning.
    It's all generally a PITA.
  • B.O. Plenty wrote:
    The harder you scrub the more of the outer wear layer you take off.
    With an EPDM rubber roof membrane, yes - with the TPO vinyl roof membrane the OP has, no - the outer layer does not rub off. That's one of the main advantages of TPO - it doesn't chalk as EPDM does. Regardless, once stains are embedded in the material it's not coming out.
  • I used to place a bar of lava soap in an old sock .. put my son on the roof and he scrubbed it clean. Looked brand new. When son moved out I decided that looking new wasn't necessary.
  • rule number one, don't worry about it. you can scrub until you wear a hole in it and it will still look dirty
  • The harder you scrub the more of the outer wear layer you take off. Lightly wash it with mild soap and a soft brush and rinse it off maybe once or twice a year. That's all. Nobody will notice, or care.
    B.O.
  • When I had a EPDM roof, it was the same. No way to get it pure white. I cleaned it real good with Dawn dish detergent let it dry, and put two coats of Kool Coat on it and it looked good for 12 years.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 03, 2025
