You don't accurate weights yet. You will not until you load the truck, and trailer ready for travel and then weight the truck unhitched, and then truck and trailer together on real scales, that will weight all the different axles separately.
The CAT scales, found at many truck stops, have a scale platform that will weight the front axle, rear axle, and the trailer axles.
Get this, and then you can get some correct answers. But I'd hazard a guess, you are 1) way under on your guestimates, and way over on your cargo capacty, and probably rear axle weight allowance.
ericbos wrote:
I put some more accurate weights above. Sorry I didn't put that in initially
