ArmySFCRet
Jul 22, 2013Explorer
Trailer Tires "Feathering"
Replaced the Dexter axle on the car hauler due to bent axle. Now after another 1200 miles on the original tires, one run with a Hudson Hornet on board, I found that one side was feathering or cupping the tire on the inboard side and the other was doing the same on the outboard side.
This could mean an alignment problem but how do you correct alignment with a dual axle spring suspension such as this one?
Is something too tight? I have now replaced all four tires and hopefully can get this right before I wear out another set. The untouched front axle is doing fine now that I have a good progressive brake controller.
