blt2ski
Aug 12, 2013Moderator
Its probably one tire size larger or equal. P tires need to have the sidewall load amount derated 10%. so as long as this is kept in mind, you should be fine. Many smaller trailers with 13 and 14" sized tires, usually single axle come with P metric tires. I have not had any issues as Barney noted from over flexing sidewalls etc. Then again, these tires do not have a lot of sidewall to flex causing sway and other issues.
Generally speaking tho, most will recommend that one an "ST" or "LT" style tire on a trailer. Like a lot of things in life, there are exceptions, the P tires are probably less than 10% of the time will they work in most situations.
Marty
Marty
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
